You can use this interface type for CLIP management network routing in a Fabric network or Layer 3 routing network.
Important
Important
A CLIP Management Instance is not a management CLIP created in the GRT. You must create the CLIP Management Instance using the Segmented Management Instance configuration.
The following list defines the abilities of this interface type:
